Harvard
Oct 29, 2014Explorer
Quote: "Measure the resistance of the circuit."
To elaborate on this: In this case the resistance is too small to be measured directly with a typical ohm meter because the current generated by the typical ohm meter is so little. Best to measure (an estimate is probably close enough) the current in the wire and the end to end voltage drop in the length of wire (as suggested above). In this way you are creating a "high current" ohm meter which over comes the standard VOM ohm meter by using brute force (15 Amps as opposed to a few milliamps).
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
