mpierce wrote:
100 amp should have a boost button. Did the button not work?
My new trailer came with a WFCO 100 amp. Never seemed to get batteries charged. Changed it out to a PC 80 amp with pendant. MUCH BETTER.
If you have a WFCO, change it out!- BurbManExplorer III
2oldman wrote:
For that short of distance there shouldn't be any delta.
He didn't say what the distance was....in my floorplan the converter is a good 25' from the batteries. It helped quite a bit when I added a #4 in parallel to the #6 on the (+) side. Frame ground is the (-) path. - wa8yxmExplorer IIIBest to measure at battery but for the first test, Measure both, moving as quickly as possible,, that way you can tell if you need to upgrade your wire.
- UnyalliExplorer
X2
Stand alone deck mount
Power center integrated upgrade
-Jeff - mpierceExplorerMy new trailer came with a WFCO 100 amp. Never seemed to get batteries charged. Changed it out to a PC 80 amp with pendant. MUCH BETTER.
If you have a WFCO, change it out! - Save yourself the trouble and just replace the WFCO.
Otherwise for testing run your battery too low like 11.8 volts then have every possible 12v item running when you plug in. If voltage at the converter steadily rises above 14 volts you are doing better than most.
In addition to larger wire you may also need four or more batteries to get boost mode out of a 55a WFCO.
Technically you are looking for less than 13.2 volts at the converter during initial charging to trigger boost mode. Good luck. - doughereExplorerFrom your next post (you're using a WFCO) I'd add make sure converter is going to 14.4 bulk mode, if not, no amount of wire is going to help.
Doug - doughereExplorerYou need to measure at the converter, and at the battery. When charging a depleated battery (converter putting out max) I think I'd upgrade if drop is over 0.2 V.
I moved converter to compartment next to the batteries and used battery cables from the local auto parts store.
Regards,
Doug - LspanglerExplorer
I've read a lot about the WFCO not going into bulk charge mode and I'm wanting to monitor it's performance this weekend.
Linc - 2oldmanExplorer IIFor that short of distance there shouldn't be any delta.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
