landyacht318
Nov 29, 2016Explorer
Have a reason for the ambivalence toward Deoxit Gold g5?
Cell phone micro usb connections 'should' never require the aggressiveness of d100.
Gold's description seems perfect for a micro USB connector.
source
BTW the link I posted in previous post is for a sub 2$ plug in wall charger for a Samsung s3 battery which has been removed from phone, as it seems the failure of the microUSB receptacle in the phone, is a given, the only variable is the time/ insertion removal cycles to failure.
and the amount of leverage applied to plug during its life.
DeoxIT® Gold (formerly ProGold), is a unique conditioning solution that improves conductivity and provides long-lasting protection on gold, base metals and other precious metal contacts and connections (gold, silver, rhodium, copper, bronze, nickel, etc.).
Use on plated connectors, contacts and metal surfaces for maximum performance and protection.
Recommended for critical applications where only slight cleaning action is necessary. If the surface looks clean, applying DeoxIT D-Series contact cleaner first is usually not necessary. DeoxIT® Gold is designed to dissolve small amounts of oxidation. Apply DeoxIT® Gold after DeoxIT® D-Series contact cleaner on plated metal surfaces, except where noted with DeoxIT® Shield S-Series below. The more critical the connection or part, especially low current applications, DeoxIT® Gold should be the final step.
For reference, DeoxIT® Gold has approximately 0.5% cleaning action.
source
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
