don_a
Mar 31, 2018Explorer
MegaWatt S-400 as boost charger up in smoke
It looks like this discussion is archived and can't be reopened (another example of some topics being locked up that are best kept open because the solution remains relevant), but that's another topic for another day. Today I want to warn anyone not to make the same mistake I did by following an old post here, and to supply the details to hopefully prevent someone else from repeating it and burning up a relatively expensive device. I was following a philosophy stated here of using a Megawatt S-400, setting it to 14.8V and attempting to change a battery while using a wind up timer to energize the MegaWatt for a short amount of time.
I had two Costco GC2's in series in my coach that had discharged to about 85% according to my battery monitor when I started the generator. I then twisted the timer for 40 minutes and began to read while I waited. I noticed 36A charge reading right off the bat on the battery monitor so I decided to check the voltage on the actual battery terminals to see if anything was awry. (I had set the MegaWatt to 14.8V via the adjustment pot reading it with no load.) The voltage on the battery terminals read 14.3V which . After about 15 minutes of rapid-charging I smelled something a little odd and by 30 minutes the power supply had shorted out internally and tripped the GFI.
Calling the manufacturer, the support person said that the charger would only produce 30A long term and that I burnt it up by not following the suggested amperage limitation. (There is no built in regulator for the device he stated.)
Anyway I have a boat anchor now so other people who want to build a single stage "boost only" charger from previous suggestions in this forum should keep this in mind if your 14.8V boost supply is rated at under 30A in reality as this one is (apparently).
