howardwheeler
Aug 12, 2020Explorer
We have apparently made a mistake in trusting the specs Xantrex publishes for their 24 volt units. If we could get it to do what it is, in fact, capable of (you can indeed set proper voltage parameters for absorption so it will work) then we would have no problem. I sure hope we can make this thing work because selling it will bring a big hit. But it has to work right. It has all the hardware capability we need. It's just the way it's programmed. I wish someone knew how to hack into it. We are in any event going to install a cut off contactor on the AC coming into the Xantrex as a safety. I believe MrWizaed is right about splitting the units into two. But I'm financially married to this Xantrex until I get grounds for abandonment.
