MrWizard
Aug 12, 2020Moderator
There is still the problem of
Will the Xantrex output a charge current
When it can't do voltage read of the batteries
This might be the basis of the "current" situation
Can the Xantrex actually read the battery voltage or is reading the BMS
Have you tested this, have you connected (2) 12v in series and connected them to the Xantrex to see if it obeys the 25.?v absorb command
