BFL13's avatar
BFL13
Explorer II
Dec 08, 2015
Mex's Flash?
Does "Flash charging" mean we (some of us anyway) are wrong to hate it when the PowerMax or Iota converters drop their voltages so soon for the absorption stage?
In another thread Mex says, "A flash formula is to achieve absorbsion limit (I prefer 14.8) as fast as possible then maintain it there until all battery cells start to bubble lightly, then back off to an intermediate voltage, perhaps 14.0 volts. The bubbling will subside at the lower voltage, but when it resumes, drop the charge rate to float."
I think Mex is saying he likes to have no constant amps stage at all, but have such a high charging rate (charging amps wrt size of bank in AH, that the voltage spikes to the top immediately and amps taper while voltage remains constant at the high point for a time after that
(This thread linked below is about something else, but I need to refer to the graphs in its OP and this is the easiest way to show them with my computer lack of skill.)
So that would look like the later recharges in the second and third graphs here I think, where the bank has shrunk in AH, making the charging rate higher, and so the constant amps stage is lost.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24849190.cfm
But then he says to wait during the absorption stage till bubbles start and then drop the voltage. BUT that means when you reach "gassing voltage", which I thought was when you first reach that (14.x volts) which in Mex's case would be right away not later.
Or are we getting into the tiny bubbles counting again? I don't think taking the caps off is practical or desirable for normal recharging, but ???
I don't know if Mex's flash profile would get you high enough in SOC before the bubbles make you lower the voltage. I would want to keep the voltage at its high point until at 90% SOC anyway (doing 50-90s)
You wouldn't do a generator recharge above 90% SOC, so that seems to suggest Mex lowers the voltage sooner. But that would reduce the amps acceptance rate, and slow down the recharge, but Mex says the flash method is the fastest.
So, Mex, what is it that I am missing ? Thanks
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
