I have a bad coil 120-105452-6 and have a replacement 120-105752-6 bith made by white rogers and need to know if they are interchangeble. White Rogers says they have no info. Need help.
I maybe reading this backward. My rig uses four pole and the ground goes through the battery control circuitry to delay closing the relay until primary battery had reached a specified level. If he is replacing a three pole with a four pole then yes, he just needs to provide a good solid ground to the bracket. If the bad replay is a four pole and the replacement is a three pole, then it will not work.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
