Old-Biscuit
Nov 26, 2017Explorer III
Propane Lights off..stays lit------BUT NO cooling effect
Electric doesn't get hot
(Check that the 120V AC Outlet cord plugs into actually works.......then check the 5A Fuse on control board---it is the glass fuse. Have to unplug AC Power cord AND DC leads to remove cover)
IF the 5A Fuse is blown then element could be bad----BOTH have to work for electric to function)
Cooling unit could be BAD
Unplug electric heater element LEADS from control board
Plug them directly into the 120V AC Outlet.......run fridge this way for minimum of 12 hours. This method will force cool fridge IF cooling unit is functional.
If fridge does NOT cool down......cooling unit blocked/obstructed---replace
Think you will find cooling unit BAD
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
