BFL13
Feb 08, 2020Explorer II
The OP is using 1/4 etc, suggesting he is using the LP monitor on his range hood and not the actual gauge on the tank. As noted above, "full" and "half" are not the same on the two.
The lowest light on the monitor indicates from when it first turns to only that light and stays that way until all the LP is gone, so how much it takes to refill varies. Also ISTR that amount varies "as corrected" for temperature.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
