Chum_lee
Feb 08, 2020Explorer
down home wrote:
Clerk who filled it this am suggested letting it run out and opening petcock somewhere on the tank to let moisture out. I think he must have meant lube. Neither seems reasonable.
You are correct!
IMO, it is NEVER a good idea to intentionally allow a refillable propane/butane tank to go empty and remain at at/open to atmospheric pressure for any length of time. That's what gives moisture (and other contaminants) an opportunity to enter the tank. (unless you suspect that the tank is already contaminated) If so, the tank should be professionally inspected before filling/use.
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
