- Discovery8Explorer
D.E.Bishop wrote:
Discovery8, I have another suggestion for you. It may keep the grey hairs to a minimum. Google The 12 volt side of life. Oh yeah, then go there and read both sections. You will save yourself a lot of time and worry.
Next, Google, RV 120 volt AC circuits. Same thing here. I don't have a suggestion for a specific site, I have been in the trade since I was 14 and just kind off know a lot.
Two tools I would reccomend you buy are a 12 vdc test light, and a 120 volt ac non-contact probe. When you can use those tools with convidence, you can go to a inexpensive DMM or Digital MultiMeter.
Good luck and relax, it's really simple and easy to learn.
Thank you for the information. I appreciate it. - D_E_BishopExplorerDiscovery8, I have another suggestion for you. It may keep the grey hairs to a minimum. Google The 12 volt side of life. Oh yeah, then go there and read both sections. You will save yourself a lot of time and worry.
Good luck and relax, it's really simple and easy to learn. - Discovery8Explorer
pianotuna wrote:
Hi,
If the gfci will not reset there are three possible causes.
1. there is no power to the outlet
2. there is a fault at the gfci or down stream from it
3. the gfci is simply worn out.
As you have multiple devices without power, my money is on #1. This means, in your case, that it is probably time to call in a professional.
Thanks for responding.Discovery8 wrote:
The GFCI outlet will not reset. - Discovery8Explorer
Artum Snowbird wrote:
Because you have lost a considerable number of outlets and devices, you have likely lost one side of your 50 Amp service. If you can reach a different 50 amp receptacle from your unit, even with a 50 amp extension, try that.
Your power comes into the panel on two sides of your breaker panel. If all your losses are on one side of a double sided board, you have lost one side. If all your losses are every second receptacle in the panel board, you have lost one side.
It's either that way on the plug in outside, or something in your plug or in your panel has become disconnected.
Further to your problems, your inverter will be fed from only one side of your 50 amp panel, so it is very likely that because of your dimming lights, either the inverter has not got enough power from the failing circuit, or if as others have said, it's a flow through inverter, then the feed through the inverter has a loose wire in it possibly.
Do a circuit by circuit analysis of your panel to determine if all the bad things are on one side of your 50 amp service first, then get competent help with that knowledge in hand. Do not replace anything until you figure out why it is not working properly.
Thanks for the information. This is helpful. - Discovery8Explorer
D.E.Bishop wrote:
Discovery8, if you aren't familiar with GFCI, here is a extra simple explanation. The GFCI prevents electricity in a circuit from back feeding on the neutral or ground circuits and killing you. How is not important for you to know. You do, however, need to know how to test and reset the outlet should it trip.
If you look at a GFCI you will notice that there are two buttons between the outlets, one is engraved with the word TEST and the other is engraved with the word RESET. When a fault is detected the button that says, RESET, will protrude slightly. If your GFCI's button is protruding, it needs to be pushed in until a click is heard.
If it will not stay in, disconnect every power cord in the dead outlets.
If it will not reset after removing all the cords in the dead outlets, I would suggest that you should call someone who is knowledgeable regarding residential wiring.
Normally GFCIs are installed in wet areas like kitchens and bathrooms or for outside outlets. The microwave falls into the kitchen area and the use of a GFCI is probable in that circuit.
This is not a diagnosis of your problem, it is just so~ething you really need to know.
Thank you. This is helpful. - Artum_SnowbirdExplorerBecause you have lost a considerable number of outlets and devices, you have likely lost one side of your 50 Amp service. If you can reach a different 50 amp receptacle from your unit, even with a 50 amp extension, try that.
Do a circuit by circuit analysis of your panel to determine if all the bad things are on one side of your 50 amp service first, then get competent help with that knowledge in hand. Do not replace anything until you figure out why it is not working properly. - pianotunaNomad IIIHi,
As you have multiple devices without power, my money is on #1. This means, in your case, that it is probably time to call in a professional.Discovery8 wrote:
Rick Jay wrote:
Discovery8,
Maybe I missed it, but did you Reset the GFCI? Perhaps it tripped either due to water intrusion or someone accidentally pressed the "Test" button.
The first year we had our motorhome, we were in the rig watching the front TV. All of a sudden, the TV lost power. I was checking breakers, measuring voltages...then I realized our then 4 year old daughter was on the potty and she was intrigued by the red & black buttons on the GFCI outlet. Problem solved! LOL
Good Luck,
~Rick
The GFCI outlet will not reset. - D_E_BishopExplorerDiscovery8, if you aren't familiar with GFCI, here is a extra simple explanation. The GFCI prevents electricity in a circuit from back feeding on the neutral or ground circuits and killing you. How is not important for you to know. You do, however, need to know how to test and reset the outlet should it trip.
This is not a diagnosis of your problem, it is just so~ething you really need to know. - wa8yxmExplorer IIIOk I will give you the power path to TV's and MIcrowave in MY RV. I will note options so this path fits nearly all RVs.
Shore power ---Auto Transfer Switch---Breaker box--30 amp branch---Inverter/charter---Sub panel---and then two 15 amp branches (out of 3) one to Microwave, One to Televisions and electronics (Both front and rear) and the 3rd to the GFCI chain.
The inverter and sub panel are optional
On some RV's. the Microwave and/or Television may be on GFCI.s
On some the Sub panel is part of the Inverter/Charger IF YOU HAVE ONE.
I had a RVer come to me for help... Half his RV had no 120 volt power.. One of the breakers on his inverter was clearly tripped.
Re-set.. he went inside his wife ask "Does he think he can help" hubby answered "He's already fixed it".. Just that fast.
Note that my RV did not COME with the inverter and sub panel they are after market add-ons so I know about 'em.
Page 2:
Sometimes you can trip ONE of the two park 50 amp breakers or your main breaker. Or sometimes ONE contact will be a tad flakey on the Marinco connector.. Re-seat all plugs and so on.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
