pianotuna
Aug 18, 2018Nomad III
Hi,
If the gfci will not reset there are three possible causes.
1. there is no power to the outlet
2. there is a fault at the gfci or down stream from it
3. the gfci is simply worn out.
As you have multiple devices without power, my money is on #1. This means, in your case, that it is probably time to call in a professional.
Discovery8 wrote:
The GFCI outlet will not reset.
