- Rick_JayExplorer IIDiscovery8,
Maybe I missed it, but did you Reset the GFCI? Perhaps it tripped either due to water intrusion or someone accidentally pressed the "Test" button.
The first year we had our motorhome, we were in the rig watching the front TV. All of a sudden, the TV lost power. I was checking breakers, measuring voltages...then I realized our then 4 year old daughter was on the potty and she was intrigued by the red & black buttons on the GFCI outlet. Problem solved! LOL
Good Luck,
~Rick - Discovery8Explorer
MrWizard wrote:
you need someone with electrical experience to help you
from the sound of it you have lost the "pass-thru" of power, on the outlets fed by the inverter, there should be some push button circuit breakers mounted on the inverter/charger combo
example our previous RV a 95 Safari DP
TV, (1) kitchen outlet, bath outlet, (2) bedroom outlets, and kitchen ceiling fluorescent light, where on the inverter, this was the drivers side of the RV
every outlet on the curb side was shore or generator, not wired to the inverter
your batteries are charging from the inverter AKA No Solar ?
then the inverter has power input, but no power output, no pass thru
Thank you for taking the time to respond. This makes sense.
Yes,the batteries are charging from the inverter.
Some outlets work. The GfCI outlet, microwave, fridge and TV's have no power. - pianotunaNomad IIILack of power on one leg of the shore power supply.
Do you have any sort of meter?Discovery8 wrote:
What would cause the GFCI outlet be completely out? - MrWizardModeratoryou need someone with electrical experience to help you
then the inverter has power input, but no power output, no pass thru - Discovery8Explorer
CA Traveler wrote:
Discovery8 wrote:
No input power.
Do you know what would cause no input power? - LwiddisExplorer IIRunning the fridge on propane requires some power.
- CA_TravelerExplorer III
Discovery8 wrote:
No input power.
What would cause the GFCI outlet be completely out? - CA_TravelerExplorer IIICB = Circuit Breaker
- Discovery8ExplorerWhat would cause the GFCI outlet be completely out?
CA Traveler wrote:
Discovery8 wrote:
Yes. If you have a pass through inverter then it could also be it's input CB as well as the related panel CB.
We have noticed the interior lights in the MH have been dim for the last couple of weeks.
Could it be the inverter went bad?
Recommend you get the batteries charged while finding the problem.
Always helpful to post what you have like: mfg model xxx charger/inverter yyy watts etc.
Does CB mean Control Board?
Having RV issues? Connect with others who have been in your shoes.24,230 PostsLatest Activity: Apr 08, 2025
