coffebreak's avatar
coffebreak
Microwave trips main breaker???
have a TT 28ft with 30amp service... Have used the TT many times in the winter in vegas etc.. even with the A/C (13500) we were always able to use the micro with no problems. .... Last week our house A/C broke down (compressor) and we have been living in and still living in our TT in the back yard. Temps here in Az are about 115 daily and the A/C in the TT of course runs constantly. ....Now my question is that when we use the microwave now it runs for a few minutes and than the main breaker trips which it never did in the cooler weather... could this be happening because the temps are so hot now and the A/C is working constantly or maybe another reason? We use our coffee maker with no problem if that helps.
Thanks for any suggestions....
  • At those temperatures my Dometic 13500 draws 1900 watts. Add the fridge (325 watts) and the microwave (1570 watts in my case) and the total is far more than 3600 watts.
    A 30 amp service is intended to provide only 24 amps continuous. To translate that to watts multiply by 107 = 2568 watts. (the minimum safe voltage).
  • coffebreak wrote:
    Temps here in Az are about 115 daily and the A/C in the TT of course runs constantly. ....Now my question is that when we use the microwave now it runs for a few minutes and than the main breaker trips which it never did in the cooler weather... could this be happening because the temps are so hot now and the A/C is working constantly ...
    Absolutely. As exterior ambient temps rise so too does compressor head pressure, which in turn means it's drawing more current than it would at lower temperatures.
  • What kind of outlet are you plugged into, regular 30 amp, or 15 amp house hold outlet?? Any extension cords?? If you are plugged into a 15 amp outlet, and/or using extension cords, there is your problem.
  • I would assume you are using an extension cord to power the trailer? If so what is the length and gauge of the cord? There is a good chance the voltage dropping across the length of the cord is causing the A/C to pull more current and thus tripping the breaker when other items are used. Even if you have installed a 30 amp pedestal, that installation could prevent you getting a full thirty amps at 120V depending on the wiring and length from the house breaker box.
    Measure your voltage at other outlets when the A/C and Microwave are running and see what your voltage is. I would guess it is dropping below 110V.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
