Gdlow's avatar
Gdlow
Mirror slid off wall
While we were driving heard a thump. When we stopped a 2 1/2 x 3 ft mirror had slipped off wall. It has been there for age of coach, and was attached with some type of tape. Any thoughts as to what type tape or a tape to use or a better way to install on MH walls.
  • I would put it back up with double sided tape. After all, it worked for 12 years.
  • The SIMPLE fix is to pull the mirror off carefully with your hands and clean the back of the mirror and wall behind it with 91% alcohol to remove ALL of the old double sided tape and residue. Go to WalMart or an auto parts store and buy some wide 3M automotive gray double-side tape and place several strips horizontally along the back of the mirror a few inches apart.
    Now, here's the key: put large blots of clear RTV on the back of the mirror BETWEEN the double sided tape strips. THIS is actually what will REALLY hold your mirror to the wall. Use a goodly amount, but not too much that it interferes with the double sided tape. Make sure you use clear RTV; it is removable by rolling it with your thumb should you ever want to remove it and it will NOT hurt the surface it is applied to.
    Hang the mirror back on the wall.
    The double sided tape's primary purpose is to hold the mirror in place while the RTV cures (about 24 hours) and even if the double sided tape "lets go" (highly unlikely with the 3M product) the RTV absolutely WILL keep the mirror from falling in the future.
    Again, the 3M automotive double sided tape is GREAT stuff and won't likely fail especially if you use enough of it and prep the surface with the 91% alcohol. It is designed to be used on shiny automotive exterior paint in the blinding hot sun while exposed to the rain and elements to hold trim and molding on cars. Sure, it's hot in an RV when the A/C is off stored somewhere when not in use, but not NEARLY as hot as on the bodyside cladding of a 1995 black Pontiac sitting in the blistering Arizona sun...which is what the 3M tape was designed to be used on.
    However, in the event that the 3M tape DID fail, the RTV again WILL keep your mirror from EVER falling off again. Both of them together are bullet-proof. That laminate wall is going to come apart before the 3M tape and RTV fails.
    This is an EASY fix that WILL work...and you don't need to use ugly dollar store 1950's mobile home mirror clips or do a patch job by adding out of place wood strips to hold the mirror in place.
    Hope this helps!
  • j-d's avatar
    j-d
    Explorer II
    Or put a molding around it, or maybe some clips, along the lines of this
    RV walls aren't very thick or rugged, but they'll support something like a mirror if you use several small screws. Remember to put most of the support across the bottom.
  • Unless you think you might want to remove it at some time, I would place a couple of temporary nails at the bottom edge to hold it up then use a large quantity of liquid nail on the wall and press it into it. remove nails after glue dries and fill holes if visible.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
