MEXICOWANDERER wrote:
Keep in mind...
A battery manufacturer is going to insist on care and maintenance that makes the battery and them look "the best".
Charging time requirements, worn-out generators and long drives for gasoline are no object - optimum battery life is number one. Even if 10% added battery life costs 40% of the original cost of the battery.
Back float voltages down to the point where a fully charged battery does not lose or degrade the density of the OEM specific gravity of a fully charged new battery. This is trial and error. No 24 pin logic chip on the face of the earth can replicate this protocol.
Once a year watering? Mena, try not to imagine nits to pick too hard. Engineers have to say -something- or they eventually get a pink slip. "Hey there Roy, tell us why we are paying you 80K a year?"
Battery manufacturer's "instructions" should be regarded as tips and hints. Not gospel!
Armed with a voltmeter and a hydrometer an informed consumer can rip the shorts off any battery engineer whose guesses are far removed from the site of the battery itself. I wouldn't argue with BFL13, or Mena, for instance for all the tea in China. What they find is reality. It's foolish to try and outguess facts.
Thank you for weighing in MEX! Since I have this adjustable power supply now, I'll play with the voltages to see what happens to SG. I know 13.6V works. I have it at 13.2V now. Once the acid gets mixed up, I'll play around and see what's best for fun. But if 13.2V works for a summer voltage, I'll just leave it at that.
