phemens's avatar
phemens
Mixing solar panels
Hope I don't confused anyone too much, I get muddled with all the numbers, I'm by no means proficient in this, so looking for advice.
I currently have 2 solar arrays. One is 2x325w 72 cell panels in series feeding a Victron 100/50 MPPT. Not planning on touching that one. The other array is a single 250w 60 cell panel feeding a separate Victron 100/30 MPPT. Current total wattage is 900w.
I have room on the roof for 1 more large panel that I was planning to wire in series with the single 250w panel. Ideally I would have preferred to avoid replacing the existing MPPT, but the max wattage for the 100/30 is 440w @ 12v. The unit is able to handle wattage above maximum, but it would be wasted (manual states "If more PV power is connected, the controller will limit input power.").
So here's the question - if I stick with the 250w panel and add another one in series, then am I correct in assuming that I should stick as closely to the rated amperage of the installed panel (8.24A) with any new one (i.e. no point in going to a 300w panel)?
The end objective is to add enough solar to reliably power a residential fridge and get off of propane. I have 600 A/H of LifePO4 (500 A/H usable). The primary consideration is not price (but is a secondary one), it is reliability of the system as we plan to leave the trailer at a remote location for extended periods and I don't necessarily want to worry about propane running out when we're away.
Thanks for your input.
  • phemens wrote:
    BFL13 wrote:
    Having your own land like that lets you park so you can tilt the panels South. The stick house can be built with the roof slanting the right way too. At our seasonal off grid, I beat that by using a ground based solar set that I could aim, so it didn't matter which way the trailer was parked.
    You want the fridge on the North side, the panels tilted South, and the awning on the sunny side. Of course your RV will have the fridge on the wrong side!
    Plan for the house is to have the solar array on a tracking mount to follow the sun. Boss has dictated that the house will be build to consider view first, practicality 2nd ;)
    And remember, the boss is always right.
    A lot of times you are but remember rule no. 1 above.
    Trackers are not much use unless there are space constraints. They use a fair bit of energy and don't do well in winds. They are also expensive.
    Far better to use that money for more panels set at the ideal winter angle.
  • No space constraints for sure. If not tracking then arrays that I can easily access to keep clean. I have a whole education on home solar ahead of me ;)
    I would start with a floor plan that satisfies your partner. Next a passive solar design. The fewer mechanical systems the better.
    The eco house in Regina had back up heating consisting of a natural gas fired 40 gallon water heater. It used evacuated tubes for space heating, and the windows had a wide gap where Styrofoam peanuts were blown in at night--and then sucked out in the morning. There were no north facing windows. They did use an air to air heat exchange system.
    There were two water heaters "in series" the first one only had the pilot running to preheat water.
    Will you go 100% electric? A ground heat pump system would be a nice but expensive feature.
    I have a triple mini split heat pump in my condo. I've never needed the heating part, but it is unbelievably efficient. My current consumption is 4.3 kwh per day. I suspect most of that is the fridge. I do have a dishwasher, microwave, and induction cook top with a resistance convection oven. My space heating and water heating costs are hidden in the condo fees.
    The very first geothermal house in Saskatchewan is near the Manitoba border--and the owners are piano tuning clients of mine. It was monitored for more than a few years by the National Science Counsel from Ottawa. At that time two wells were bored. One for drawing hot water and one for injecting the water back down. Current technology uses a field system that is buried at two layers about ten feet below the surface. I have one client who has the newer system. It is NOT cheap. The mechanical components take up a fair size room.
    None of these installations included solar electric generation--but the more modern heat pump folks plan to do so.
  • I quickly scanned n didnt see the answer I am thinking.
    A residential fridge is hugely inefficient. If you have a few bucks, and plan to do RVing in the future also, then reconsider all this.
    You have plenty of solar for a vehicle compressor fridge, by this I mean the Danfoss-style compressor unit (Engle, ARB, Dometic, Iceco etc). These are made to run off batteries/solar, and the compressor is advanced and uses very little power compared to a house fridge of similar size.
    Using a house fridge will suck the batteries low over-night and this will shorten the battery life, and cost more money down the road.
    Save the cost of extra panels ($300??) and put it into a unit with the Danfoss compressor. I think someone mentioned a retro-fit for a compressor to fit into some propane RV fridges, this is good as the typical Dometic compressor is a chest style, but there are options for front opening also.
    The nice compressor models with two compartments (can be freezer and fridge) are expensive, but no need to point out the benefits anymore given the current social disruptions out there.
    I have a big, two door chest, with two GC batteries, and lose very little battery charge overnight. Batteries are topped off before I get out of bed from 200 watts solar.
    The compressor might run 7-10 mins per hour and pull 3-5 amps max, I think around 3-4 is typical. A residential fridge would run through an inverter with its own power loss and draw much more power.
    Residential fridges are not made for being driven around a lot, though they can hold up it seems, but the vehicle fridges are used and abused by off-road Jeeps all the time with no issues.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
