wiredgeorge
Apr 07, 2018Explorer
Wow. Thanks for the post BFL13. I had made some (hate using the word) assumptions on how the probes worked. The webpage you sent cleared that up. Will have to check voltage on the wires to see if they are connected correctly I guess. I did drain the tank and the probes are new. I did a back flush using the hose in the clear elbow gizmo but the bend is sharp going up to the black tank so am not sure if this fully cleaned the thing. I have a wand and will stick it down the toilet and see if that produces any results.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
