  • DrewE wrote:
    You should be able to swap the wires to the two tanks, at least assuming this uses anything like a halfway typical tank monitor circuit.
    I would also guess that a little cleverness and work with a drill press might allow one to replace all the bubble switches with normal pushbutton switches, and probably with a little care it could be done fairly neatly.
    Thanks for the advise. Will try the wire swap. Thanks for input.
  • DrewE's avatar
    DrewE
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
