marc71's avatar
marc71
Monitor Panel
Just came home with another travel trailer. 2015 Jayflight 32 BHDS. It has a KIB monitor panel with the switches for water pump, electric and gas water heater operation. All of the switches function, water pump runs and gas fires on the water heater. Here’s my issue, none of the lights work. The switch lights do not come on and none of the lights come on when I press the tank levels or battery level. Anyone have a suggestion on what it could be. Everything else in the trailer operates as it should.
  • Problem solved. I sent an email to KIB the manufacturer of the panel last night. I was advised to check for a bad ground, took the four screws out removed the panel and tightened up the connector on the white ground wire, everything is working perfect.
  • Search on Amazon for KIB monitor panel
    Not sure which panel you have but the link above has several to choose from. All the indicator lights are LEDs so they should still work. The lights in the switches are another story. They're probably incandescent lamps and often burn out. Get at the panel and check for voltage to the lamps when they should be on. It might be easier for you to replace the panel.
  • DrewE's avatar
    DrewE
    Explorer III
    My guess would be power (or ground) to the monitor panel. The other switches are electrically separate things, though mounted to the same panel. It might be something as simple as a 12V fuse that's blown or loose.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
