time2roll
Sep 06, 2014Nomad
Keep all four batteries right together and wired up with no switches for best performance.
If converter is placed close to the battery the existing main feed to the existing 12v panel is fine. You can even connect a 300w inverter using the existing feed. Small transfer switch and the tv/dvd/satellite circuit is on with the touch of the remote button. No pulling wire, just make connections.
I would be looking more at 9280 or 90 amp IOTA vs the 9260. Although this might be a bit much if just using a Honda 2000. 40a max for Honda 1000.
