sjturbo
Sep 06, 2014Explorer
Thanks RoyB, That's great! I need to look it over and get back with questions! First on is, does the four way switch allow the use of either bank as well as the two in parallel?
smkettner, are you recommending the higher amperage PD in order to charge the batteries more effectively? One thing I need to add is I will likely use my Honda eu3000 into a Mega Watt S-350-12 for charging.
