sjturbo
Sep 06, 2014Explorer
Thanks Niner! Actually the four Crowns are rated at 470ah. And according to the "Crown battery requirements, The Bible" that you linked me to it indicates a charge factor of 1.07 (107%) to be fully recharged. 470ah/2 = 235ah*107%=251.45ah for a complete recharge. I think I have that correct. It appears that none of the PD9200 converters can supply the 15.3vdc needed to top off the batteries, (more like 14.4 to 14.6vdc? with the pendant). I thought that is why MW suggested the Mega Watt power supply since the voltage can be adjusted to above 15vdc likely 15.5vdc. If I am boondocking and the only ac source I have is the Honda eu3000 I thought the Mega Watt was a logical alternative. I certainly like the solar idea and somewhere down the line I may invest in what you have noted. Until then the eu3000 is my only choice?
