mena661
Sep 07, 2014Explorer
BFL13 wrote:If I set the MW to 15.45V (mine maxes out there) and the batt voltage gets to 15.45V, my batts are taking 8 amps.
How many amps will four batts accept at 15+ volts at over 90% SOC? Be more than 5a each at 90% at 14.5v. No idea. It will taper from 90-99% SOC whatever it starts at. Say it is 8a per batt for this math exercise--might be more than 8 really--so now you can do 4 x 8 =32a on four at 90%. If you try 40a and they will only take 32, then 32 is what you will see going in even if you try to shove in 40 :)
