sjturbo
Sep 13, 2014Explorer
Thanks for the reply Ken. If you look closely the WFCO converter is not in the proposed diagram, it is no longer working. My concern is the way I will have the battery, converter, disconnect and Victron shunt wired into the existing wiring. I just want to make sure everything is going to work. Notice that the WFCO converter is wired to the +VCC. The PD would feed the DC distribution board through the + connection on the distribution board.
