time2roll
Sep 14, 2014Nomad
If the shunt is first the monitor remains powered up afaik. So battery is not fully off.
I tend to put the cut-off switch (fully insulated) on the positive as that is the convention of the system. All other switches and fuses are on the positive side. Non-insulated knife switch etc. I would put on the negative as it leaves a lot of metal exposed for a short. Electrically it is the same effect.
