ken_white
Sep 15, 2014Explorer
smkettner wrote:
Where does the monitor get power? I assume from the positive and from the shunt connection. Otherwise yes off is off regardless of the terminal.
Yes if removing a cable it is always SOP to remove the negative cable first and reconnect last.
The monitor would not get power through the shunt, it would need a solid ground (0V reference) connection, not one that varied with battery charging/load.
The shunt typically feeds a very high input impedance circuit in the monitor so minimal loading will occur.
EDIT: See my below comments for an active shunt versus a passive shunt.
