ken_white
Sep 15, 2014Explorer
smkettner wrote:
See page 1 of the Victron 600 manual
The monitor is still powered up if the switch is after the shunt.
Yep, the Victron does not really use a shunt but rather a shunt and signal conditioner all in one and it connects directly to the battery in that configuration.
A real shunt is nothing more than a very low ohm resistor (a passive device) that supplies a voltage proportional to current back to a display or control board.
If he has that Victron, then he would need to put the shunt on the other side of the disconnect to turn off the active devices.
I guess it depends on what he is using.
