time2roll
Sep 15, 2014Nomad
MEXICOWANDERER wrote:
Is there any reason the interrupting power switch should not be placed between the shunt and battery negative? Is the monitor memory volatile?
Battery negative ----> Switch ----> Shunt; was my suggestion. Although my preference is an insulated switch on the positive.
Non-volatile memory should allow the monitor to wake up and operate with minimal adjustments.
