sjturbo's avatar
sjturbo
More battery/converter/inverter questions
As many of you know I have been asking many questions and greatly appreciate all of your inputs. It seems the more I read the more questions I have. I have ordered a Mega Watt PS to Top Charge and EQ my batteries based on much feedback. I will likely be getting a PD9260 to replace my WFCO which has given up the ghost. And I will be installing four 6V GC batteries. Now for questions.
1. Should I set up two 6V series banks or one series/parallel bank?
2. I would like to put the new converter close to the batteries. Will I need to run connections back to the DC distribution panel or can I use the wires already there from the WFCO panel to the batteries?
I would like to hook up an inverter to run TV/sat.. Are there any online diagrams that I could study?
  • Ditto on the marine components. I use them on all my vehicular projects. Do it once, do it right. I really hate warranty repairs, especially on my own work.
  • Sorry larosa, I believe I could have worded it differently. I am aware of the battery hook up scheme. What I meant was two 6v in series = 12v. Setting up two of these as independent banks. I had read that setting up four series/parallel may have issues other than taking longer to charge. What would be the pros and cons of each setup?
  • RoyB's avatar
    RoyB
    Explorer II
    Here is a couple of block diagrams I did up for someone not too long ago asking similar questions.
    I like using BLUE SEA MARINE QUALITY components and ANCOR Marine Cable and ring terminals...
    enjoy...
    Roy Ken
  • 1. Should I set up two 6V series banks or one series/parallel bank?
    There is only one way to hook up 4 - 6v batterys...
