tvfrfireman's avatar
tvfrfireman
More Schwintec problems
I spent a lot of time replacing one motor, rack and parts on one end, controller. etc..... It worked for a while now when trying to open it moves about one half inch and stops. It will reverse with no problem but each time I try to get it out, it stops after one half inch movement. There is no visible code on the controller. If a wait a while, it will go out another half inch and stop. Like I said there is no code. I can peak in and the rollers are fine as are the racks and other parts. If I use the controller to override the system, it goes in and out as smooth as silk. I called the factory and they said they could not help me. The 4 6 volt batteries are fully charged and brand new. I can see buy searching that schwintec's are problematic. I just want it to work so I can trade the trailer in. Thanks in advance for any help. David
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
