robatthelake
Jun 10, 2013Explorer
The Sensor is just that. It is attached to the Battery to monitor the Temperature so it doesn't matter where You connect it as long as it can "Feel" the Temperature.
Because Your Batteries are in separate Boxes You will need to decide which one to use. Or You could mount it between the two boxes if that is convenient. The fact that the Sensor has a Battery Terminal is because the Battery Post is an obvious point for attachment . it doesn't matter which Post that You use + or - is irrelevant !
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
