Bseader's avatar
Bseader
Motorhome won’t start
I cleaned and replaced the slide out switches in my 2000 Alpine couch. Slide outs worked great in auxiliary. Then when I tried to start the Motorhome it just clicks. Chassis batteries read 12.99. Dash lights to start engine but it just clicks. Any ideas if I could of done something by cleaning switches in the HWH panel? Have not had previous issues with Motorhome starting. I tried using the boost with no success.
  • Coach battery is either low or you need to clean the coach battery terminals or your coach battery needs replacing. Did you try starting the generator? Does you coach have an emergency start switch?
