Acampingwewillg
Nov 11, 2015Explorer II
Moved water pump...now it's acting strange!
OK....I have the Shur-flo variable speed 5.7 pump, have had it for many year's now. The location of the pump was in such a confined space(under the vanity sink and it has leaked before making repairs difficult. So after putting a new sub floor down, I decided to move the pump so that I can watch it more carefully and quickly make repairs(fix leaks). So I added about 6-7' of hose, turn it on and bled out the air. It all goes well until the pump shuts down, I can watch the water start to flow backwards and the pump will start back up but will not pick back up the prime(it sounds like its just spinning dry). I can turn a faucet back on and it will start pumping again.
I didn't have this issue before moving it...my only thought now is maybe adding a "check valve " in line close to the pump in-let? They do have a built in check valve, correct? I think I do recall that this particular pump may have had some issues with the strainer basket prior to entering the pump...anyone recall that problem? Anyways...open for idea's or suggestions?
