SoundGuy
Nov 12, 2015Explorer
Acampingwewillgo wrote:
Anyways...open for idea's or suggestions?
Yes, your pump does have a check valve in the head and it should not have any difficulty priming and maintaining that prime with just 6' of extra hose on the input side. The fact you are having this problem suggests the connection(s) may be leaking and if so could be solved by using hoses with factory assembled 1/2" NPT fittings, an example being those offered in this SHURFlo Pump Silencer Kit ... each hose is 3' long and the two can be barreled together to make up a 6' length.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
