wopachop's avatar
wopachop
Moving fridge thermistor up = warmer??
Came across this link where the guy explains how moving the thermistor higher on the cooling fins actually creates a warmer fridge temperature. Which is the opposite of what the little sticker inside the fridge directs us to do.
If you read the 1 comment there is a reply that explains his reasoning.
Second question if i unplug the thermistor from the back of the fridge will that make it cool 24/7? I accidentally turned my fridge off yesterday and didnt catch it till this morning. Got to 60F in there darn it. Its down to 45F now and leveled off for a couple hours. I pulled the thermistor completely off the fins. Any advice on that topic is appreciated as well.
https://rvrefrigeratorrepair.com/uncategorized/the-thermistor-shuffle/#:~:text=You%20may%20have%20been%20advised,food%20compartment%20of%20your%20refrigerator.&text=By%20moving%20the%20thermistor%20from,%E2%80%9Ctricking%E2%80%9D%20the%20control%20board.
  • wa8yxm wrote:
    I have read many posts and even watched a few Videos from people who seriously gotten it wrong..
    You are still getting it wrong. At least there is consistency!!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have read many posts and even watched a few Videos from people who seriously gotten it wrong.. In fact I've had to apologize for getting it bass ackwards a few times myself.
    (The difference between me and many is that apology) IN fact I think I'm about to type one elsewhere.
    The it is not that heat rises but that all other factors being the same warmer air is LESS DENSE thus it rises to the top of the chamber.. So the warmest air is at the top of the chamber
    Since the thermistor on the fins is measureing the air temp. the higher it is the hotter it is.. (ok so perhaps 1 degree hotter at most) so since it will report a higher temp to the control board the controller will try to make things COLDER.
    This may confuse some.
  • Mine was inadvertently pulled off the fin and was hanging loose inside the unit.Temp went from 38 to mid 50's and probably still climbing.Reattached,back to 38....top of fin.
  • wopachop wrote:
    Now if I pull the thermistor completely off the cooling fins, shouldnt I see fridge temp get very low before it cycles off and allows temps to rise?
    Possibly, Some Control boards react differently. There is a resistance/Ohm signal from the Thermister and if out of normal range may cause malfunction of the Cooling cycle. On Norcolds, if you disconnect(unplug) the Thermister, it will cause a BOS cooling cycle. This causes the refer to alternate between cooling and shutting off at timed intervals. But, for a lot letting it hang down will cause 24/7 operation, until the refer Thermister gets cold enough if that is possible. Remember, The Thermister senses the FIN temp, not the air temp. The fin temp will be 10 degrees colder than the actual refer temp. No harm in trying, post what happens. Doug
  • Now if I pull the thermistor completely off the cooling fins, shouldnt I see fridge temp get very low before it cycles off and allows temps to rise?
  • Moving the Thermister is for AUTO temp refers that have no adjustable tstat. That is why the OEM(refer maker) installs that sticker. If you have an adjustable tstat on the control panel moving does nothing. As the link stated, you only get about 4 to 5 degrees colder difference. Doug
  • DrewE's avatar
    DrewE
    Explorer III
    I'd trust the sticker put there by the makers of the fridge over the opinion of some random guy (or gal) making a web page somewhere on the internet as to which direction to move the thermistor to achieve some particular end. For that matter, I'd trust the fridge maker's directions over anything suggested by a random poster possibly called DrewE on some RV related web forum, too, all other things being equal.
