pianotuna's avatar
pianotuna
Nomad III
Jun 08, 2013
moving from 225R75/16 to 235R85/16 PROBLEMS
Hi,
More problems have reared their heads.
The E-450 has a different rear axle, than the F-450. The F-450 will allow up to a 245 width with no change of rim size for the rear duals.
The E-450 won't allow anything wider than the 225 size.
Possible solutions:
#1 Get seven Chev rims and have them machined out to fit the Ford axle. However, they MAY not fit around the brake. It would be pretty expensive to find out.
#2 use a 1/4 inch spacer this would still leave the existing rim contact on the hub. Load the water tanks (black grey and fresh) and the gas tank to the brim. Check to see if there is sufficient clearance.
#3 give up and use the OEM size.
What would you do?
  • Hi pnichols,
    Everything I've read suggests that wider tires have less rolling resistance than narrower ones. The brands I'm considering are Michelin and Toyo.
    pnichols wrote:
    Don,
    I'd recommend looking at going to a Load Range E 215/85R16 set of tires - I did in the summer of 2011. This is actually a taller tire (about 1.2 inches larger diameter than the stock 225/75R15 size), so you wind up with about 0.6 inches of more ground clearance. The load versus pressure ratings are identical for the two Load Range E tires. The tread width is about 0.5 narrower with the 215/85R16 size, so you get better air cooling between the rear duals. If you get Michelins, you also get slightly better gas mileage from their 215/85R16 tires because they have less rolling friction.
    Think about it, unless you really need the higher load capacity of the 235's!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    robatthelake wrote:
    Use the original stock size Rims and Tires. I can see no reason to change something that works.
    There are several cases I have read recently where someone went to get new tires only to be told "They don't make that size anymore"
    In fact.. I expect to hear that when I go to get new tires.
    When this happens... Changing or scrapping are your only options.
  • I'm struggling with the idea that the wheels from an F-450 don't fit on an E-450. A bit more explanation is in order.
  • Interesting idea. IMO Michelins are also more likely to have the highest safety margin built in above and beyond the ratings in their inflation tables. There was a reason they would allow you to run 7 years instead of 5 (I wonder if that is still true).
    Blow outs and delaminations on properly cared for C tires for vehicles near their weight limits always used to be heavily biased toward the inner tires of the pair, probably because of reduced cooling. The most margin in the tire (by carefully selecting brand and model - was once XPS as the very best) along with extra dually spacing could be a good answer.
    But it does take 4 or 6 wheels which gets expensive. Simply upgrading the tires to the best available can also go a long way toward increasing margin on weight and ride quality.
    Jim
  • Don,
  • Hmm I wonder what Quigly uses when they convert E series to 4WD? Maybe they put in an F series axle as part of the conversion. I could SWEAR somewhere in my foggy memory I've seen someone successfully do what you want to...
    Jim
  • Hi Jim,
    Apparently not.
    HiTech wrote:
    So there are no alternate offset outer wheels that will accommodate the E450 axle with no spacer required?
    Jim
  • So there are no alternate offset outer wheels that will accommodate the E450 axle with no spacer required?
    Jim
  • Use the original stock size Rims and Tires. I can see no reason to change something that works.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
