KJINTF
Dec 27, 2014Explorer
Posted By: Salvo on 12/27/14 03:11pm
Parallel is shade tolerant.
Your putting too much emphasis on the size of cables. The cable runs in a RV are short; perhaps 15 ft. The cost of bigger cables isn't significant.
You pay the piper somewhere. Go with higher voltage and charge controller efficiency drops.
KJINTF wrote:
Guess I just do not understand why anyone is using a MPPT controller with a nominal 12Vdc panels connected in parallel
I see/hear of many installations including AM solar installs with several 100% parallel connected 100 watt nominal 12Vdc panels (sometimes 600 watts or more) which include a MPPT controller, never have understood why.
Anyone know???????????
Sal thanks for the response
I understand shade tolerance
Yes typical RV cable runs are less than 20ft or so one way run
Was asking why so many installations including the AM Solar installs use a MPPT controller as compared to the lower cost PWM controller for the parallel nominal 12Vdc array.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
