DIVE2XS's avatar
DIVE2XS
Multi Inverter use
I have 3 inverters that I can use for my travel trailer. A 2000,1500, and 350 watt. Also 2-12 volt interstate batteries for storage.
It would be nice to use appliances en route or overnight. Use the refrigerator on electricity instead of propane while traveling from place to place or, microwave before disconnecting as long as the tow vehicle is connected and running to keep from having to connect and use my gas generators.
I can see using a small medical device for a longer period, say over night.The placement for this would be stationary in the bedroom.
Since using the refrigerator and microwave would be high usage, I'm guessing that the 2000 watt would be best for that as I would not be as concerned about energy usage. Placement for that would be in the kitchen area in the same area as the converter.
For the bedroom, I could run a 12 volt wire from the battery or hook into an existing 12 volt light and mount on wall in bedroom. I would use this separate as it uses less energy and would make the 2-12 volt storage batteries last longer.
I guess what I am asking is how to run/connect it all together and how to separate each inverter for the system for uses I envision.
Perhaps I have it all wrong and there is another way to do this?
Thanks for any help!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
