Multiple chargers works, but you have to learn how to get them all going depending on the set-up. For instance it is usually better to start the lowest voltage charger first and then start the higher voltage ones in sequence.
Sometimes you need to start the portable first, then turn on your converter even if the converter is the lower voltage charger. Solar can be going too or turned on last depending on what works at the time. You have to try out different sequences until you learn how your things like to do it.
If the higher voltage charger is already on, then the lower voltage charger might decide there is no work to do.
In the above picture, you see the 1093 which has 14.8 voltage in with some older Vectors at 14.6v. I have to start them first, then the 1093. Some chargers don't care they just get going.
You don't have to break up the battery bank and give each battery its own charger as you can see in the picture with four chargers all on the one battery bank. However you can clamp on to individual batteries if you run out of room on the posts to clamp to. That just means you might not see all the amps showing on the Trimetric if the shunt is not included for some chargers.
As the battery voltage rises, the lowest voltage charger quits first as the spread between its voltage and the battery's voltage shrinks to nothing and each charger drops out in turn until only the highest voltage charger is still adding any amps until it tapers out
If two equal voltage chargers are on they will add their amps as long as the battery will accept them. Once acceptance rate is down to the rating of one of the chargers you can yank the other. eg battery can accept 80amps at first, so two 40ampers will do 40 each for 80. later it will be say 30 and 30 for 60. Once it gets to 20 and 20 for 40, you can yank one and the other goes back to 40 and counts down from there again.
