pnichols
Jun 17, 2014Explorer II
Our motorhome absolutely needs two water pump switches - which it came with from Winnebago.
One is in the usual spot right on the power control center along with other functions on the panel.
The other switch is way in the back of the RV outside it and within the storage bay where the outside shower head and hose are. Since we keep the power control center water pump switch OFF a lot to help prevent a broken internal water line from ever flooding the RV along with draining all our fresh water - we of course need this outside shower water pump switch to prevent having to walk inside back to the control panel to turn ON the water pump for outside shower usage. Also if the inside switch ever fails, we have a back up switch to be able to still use the water pump without having to do field repairs right away.
