MEXICOWANDERER
Nov 03, 2015Explorer
My New LED Light Bar Specs
SPECIFICATION :
1.LED Power: 400W
2. Operating Voltage: 9-32V DC
3.Waterproof rate: IP 68
4.80pcs*5w high intensity LEDS
5. Body Color: White
6. New Cree Convex Lens
7.Material:Material: Hi-impact Aluminum Housing
8.Lens material:PMMA
9.Mounting Bracket: Stainless Mounting Hardware
10.Life Span:50000H
11.Dimensions:42inch
12.Amp Draw(DC):33A /12V , 17A / 24V
13.Beam Type:: Spot &Flood Beam Combo (12F/56S/12F)
14.Theoretical Lumens Output: 40000LM
15.Operating Lumens Output: 36000 LM
16.Weight: 6kg (Per Unit Included The Box)
17.Size:1059x88x78mm
18.The high performance of tight waterproof,dustproof,quakeproof.
19.Anti explosion
Naw, it ain't a joke. New technology OSRAM chips. Gotta feed this mutha with 10 gauge wire. An 80-ampere TYCO relay is on the way. The light this bar produces is insane. No using in hilly or curvy conditions. Dim lights when oncoming car is 2 miles away (another - not a joke). Dang near weaponized lighting.
1.LED Power: 400W
10.Life Span:50000H
19.Anti explosion
