coolmom42 wrote:
You could get a stabilizer jack like RVs use. Put it under one end of the bed platform, use a power drill to run it up/down as needed.
THAT'S IT!!!!
I had 2 old stabilizers laying around that I had thought about junking. I ended up making one of them into a motorcycle lift and also made an adapter so I could lower my four 6 volt battery tray out of my RV. There was no way to put more than 3 group 24's in the original spot so I reinforced everything and lift the steel battery box up and bolt it in. Good one coolmom
