Charlie_D_
Dec 10, 2016Explorer
Sounds like nothing works? If so I can't help except to check connections and wiggle them. That worked for mine for a while after I removed the connections cleaned and greased them
My motor then stopped moving the legs although it continued to work. Found that the key between the motor and gear had stripped. I now use a cordless drill to raise and lower. Some day I will remove again and maybe drill a small hole through the gear and shaft and pin them.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
