mgirardo
Oct 14, 2021Explorer
JTMills wrote:
Jerry, thanks. Yes, I have it plugged into an outlet right now, at our house, as well as having 2 brand new deep cycle batteries installed. The owner told me it was electric only, as opposed to propane.
Since the previous owner says it is electric only, most likely it requires 110v.
Unless you have an inverter that powers the outlet you have the fireplace plugged into, the trailer needs to be plugged into Shore Power? If you do have an inverter powering the outlet, does it offer enough watts? Electric fireplaces usually require around 1500 watts.
-Michael
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
