wa8yxm
Oct 15, 2021Explorer III
It is clear the Fireplace is in the RV which is plugged into the house
I say again get a 3 light tester and while at it an adapter so you can plug the 3LT into a 30 amp outlet (50's are a bit more complex)
Plug into other outlets in the RV GREEN-GREEN-Dark good, anything else bad DARK DARK DARK diagnostic (No power to trailer)
if the Fireplace has a plug.. replace the plug with the 3LT in that outlet Same comments GREEN GREEN Dark good any other combination bad..> DARK DARK DARK diagnostic, no 120 to outlet.
There may be a fuse in the fireplace as well. But if the 3LT test is good then you need a multi-meter. And someone who knows how to use it.
If you don't mind about a 3,000 mile hike I can test it but alas.. 3,000 is a bit of a hike.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
