ReneeG
Oct 15, 2021Explorer
Gdetrailer wrote:
Fire place may be "plugged in" to one of the outlet circuits and not hardwired to it's own circuit.
If using a plugin setup it might be possible the plug has worked loose from the outlet. Outlet may be hidden behind the fireplace.
True! Ours is plugged in but the cord and outlet are just outside it so it can be reached easily. Good point.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
