- jrnymn7ExplorerNo, Red, I wasn't sure at all.
Based on the responses here, I figured somewhere in the 65-85Ah range? And x2 batteries in parallel, that's a huge difference of 40Ah. It appears these may be near the bottom end of the scale? - red31Explorerhttp://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Battery-Marine-RV-Deep-Cycle-Dual-Purpose/_/R-NBP8240_0324598118
Dual Purpose Battery For Excellent Starting & Moderate Deep Cycle Service.
I thought you already figured out 65ah! - jrnymn7ExplorerO.K., the OP says his batteries weigh in at 40 pounds. Does this help narrow them down, as to Ah rating?
thanks! - jrnymn7Explorermex, you need a 'coolerado' unit. check it out on youtube.
- MEXICOWANDERERExplorerDown here, "sheet metal industry" means walls or roof,,,
- dclark1946Explorer
MEXICOWANDERER wrote:
Call NAPA and ask weight. 46 lbs is around tops for flooded group 24
rv batteries.
Trojan SCS 150 weighs in at 50 pounds and 100AH. If you can fit a Gr 27 in your battery box the SCS 200 weighs 60 pounds and is rated @ 115 AH. These are pricey compared to generic 12V batteries but worth it in my opinion. They work nicely for me when we dry camp in the Smokies.
Dick - jrnymn7ExplorerIn the sheet metal industry, we make it fit... with a long piece of 4x4. :)
But seriously, it completely baffles me how a motor home or trailer cannot accommodate any battery, other than some really tall scrubber or such. If I can manage to fit four 6's in a mini school bus, then surely... - MEXICOWANDERERExplorerRead the topic about a superior group 24 battery. If it's a matter of "Nothing Else Will Fit" what's a person going to do?
- red31Explorer
jrnymn7 wrote:
There IS no decent group 24 for an RV.
especially if 'DP' is part of it's name. I wouldn't want a 'MS' either unless my boat had a starter. - jrnymn7ExplorerI'm assuming 24's, with similar cca's and mca's, will also have similar Ah capacities?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
