jrnymn7's avatar
jrnymn7
Napa 24 RVS Batteries?
Anyone familiar with these... like their Ah rating and such?
Thanks!
  • BFL13 wrote:
    ISTR mena has a table for all this.
    If I only knew where that was. :S
  • jrnymn7 wrote:
    Thanks, Ron,
    Yes, the batts in question resemble the specs given for interstate SRM-24's
    The SRM-24's are rated at 5a for 16.4 hrs, so I'm assuming that means an Ah rating of 82?
    AH is supposed to be at the 20 hr rate so if 82AH the rate would be 4.1a. It is true that at 5a it would last less than 20 hrs but Peukert would say how many. Different batteries types have different Peukerts though. ISTR mena has a table for all this.
  • Thanks, Ron,
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Thanks!
    I don't know the specific answer to your question but they should be very similar to something like the Interstate 24s. There's not a big variance in the common RV/Marine 24 series batteries.
  • Just trying to get specs on them, for someone who has a pair, thanks.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Group 24 are about 75 amp hour give or take a couple amp hours (C/20 rate)
    if your battery tray is DEEP enough a GC-2 pair will fit in the same space as a Group 24 pair, and give you 220-230 amp hours, a bit heavier but you go from 150 amp hours of MARINE/deep cycle to 230 amp hours of TRUE DEEP CYCLE and that is a major bump in power storage.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
